Lets see pics of 325+ wide tires on f bods
Old 09-15-2006, 02:38 AM
LS1NewBe370's Avatar
Default Lets see pics of 325+ wide tires on f bods
Search wont work for me, and im thinking about buying some custom wheels and sticking some fat tires on them. Ill prolly be going with some 18x10.5 Fikse Fm5's, i hear that the wheels are very wide and can take a 335+ tire, is this true? I want to see some pics of 325+ wider tires on cars please.
Old 09-15-2006, 03:24 AM
Rothman's Avatar
335's will not fit a 10.5" wide wheel nor will a 325. 315 is the largest you can run on an f bod without modification or custom backspacing on the wheel. To run a 315 you will need an 11" wide rim. I personally opted for the 315's because I didn't want the added stress from backspacing on my axles.
Old 09-15-2006, 04:42 AM
blown 346's Avatar
I have the Fikse FM/5's that are 17x11 rears with 315's. I did see someone here a while back that did manage to get 335's under his SS without modifying.
Old 09-15-2006, 07:58 AM
LS1Tech Co-Founder
Nine Ball's Avatar
yeah, and they stuck out Joe-Dirt style. 315s max, unless you mini-tub the car. Everything else sticks out.
Old 09-15-2006, 01:52 PM
quickneSS's Avatar
I thought you could run a 315 on a minimum of a 10.5" rim. Correct me if I'm wrong.
Old 09-15-2006, 02:28 PM
'Trust''s Avatar
They will fit on a 10.5 rim, they may bulge a tad, but I doubt you'll notice it. You'll notice it more so with say a 315mm GS-D3 than a 315mm Nitto 555 due to the fact that the Nittos run a tad narrow.
Old 09-15-2006, 03:45 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
seems like there aren't any pics of wider tires than 315's i guess.???
Old 09-17-2006, 05:46 PM
Default lol
lol thats the main reason i posted, Fikse's are alot wider than they are rated, a buddy of mine has some 18x10.5's that are wider than my 17x11's.
Post some pics of 325+ tires please guys, thanks for the input though.
Old 09-17-2006, 07:34 PM
Judas's Avatar
[QUOTE=LS1NewBe370]Fikse's are alot wider than they are rated, a buddy of mine has some 18x10.5's that are wider than my 17x11's.QUOTE]
10.5" isn't a rating... It's a mesurment taken from the inside lip, to inside lip where the tire will be mounted. Sorry but 10.5" is 10.5".
Old 09-17-2006, 07:53 PM
CarolinaWS6's Avatar
heres a fbody with a 325 mounted in the rear
Old 09-18-2006, 01:16 AM
kornfreak_401's Avatar
325's isnt the only thing mounted in the rear
Old 09-18-2006, 11:59 AM
Default pics only please
I didnt start a thread to argue that I know a 315+ tire will fit on a Fikse 10.5 rim, I know it does so thats that. Thanks Carolina for the pic, thats the response Im looking for.
Old 09-18-2006, 12:23 PM
Red00's Avatar
I had 335 pilots on my camaro. They stuck out past the fender, no way around that, unless you mini-tub. Between them rubbing, and the way they stuck out, their not worth putting on.
Old 09-18-2006, 07:53 PM
T-REZ's Avatar
this side was off a bit,i got an APHR and now nothing comes out on either side.345-30-18s on 18x12s
Old 09-18-2006, 09:37 PM
TransAm12sec's Avatar
I have this pic saved as 345s.
Old 09-19-2006, 01:52 AM
Default ttt
thanks for the responses guys, keep them coming.
Old 09-19-2006, 02:54 AM
02blackws679ta's Avatar
those "345's" are no wider than my 315's :hmm:
Old 09-19-2006, 03:44 AM
hashtagBMW
Speed Density's Avatar
That whole *** end looks like ****.
Old 09-19-2006, 05:58 AM
Adam_346's Avatar
^^^ Just a little crooked
Quick Reply: Lets see pics of 325+ wide tires on f bods
