got my ls7 clutch to day!
finaly i got my ls7 clutch today,
i bougth a ls2 flywheel with itm what is the diffirent beatween it and the ls1 flywheel, will i notice some diffirent,
my bearing somehow.. did not reach it to me, lost somewhere beetwwn the us and iceland,
can i use the bearing that is in the car now? i realy need to know this..
The ls2 flywheel is bigger a little heavier and has got a wider friction surface. If you are talking about the throwout bearing then yes you can use the stock on. However I would advise changing it. Same thing with the pilot bearing. You can use the stock ones, but get new ones. Hope that helps. I have an ls7 putting down 520+ rwhp. It seems to be a great clutch.
ohh i was hoping that i would be ligther.. i am sure that i hafe damaged the stock one because i drove the car till it stopped,
yeah i bougth the bearings. but they did not come with the package.. and i realy need to get the car running..
ohh i am realy pisst about the ls2 flywheel being heavy-er
The LS2 flywheel is a little heavier. Heavier flywheels are better for launching the car. Both flywheels look a good deal different too.
Make sure you get a new slave cylinder too. It will come with a new throwout bearing already on it.
