Why is my car so quite and weak?
hey guys whats going on i got a 02z28 with about 71k miles on her and i put on long tubes with a x pipe with dumped bullets and not i always read about how loud peoples cars are and past 3 grand its really loud but mines not really that loud and also when i gun it it bogs alot at wot in almost every gear(MN6 )whys is that any thoughts guys thanks guys always apreciate it. by the way i also get a check engine light every once in a while and it always says it has something to do with a 02 sensor
This is unusuall, because I have the same system and its the loudest I've ever heard. Maybe you have a spark plug thats not firing and your running on 7 cylinders. Does the acceleration feel considerably slower than it used to?
did you get it tuned? headers tend to make you run rich..would do what your saying. The loudness part...sound is SUBJECTIVE. People say my rumbler is loud..I think its quiet.
i dont think not getting it tuned is the problem. i know of many cars that run fine without it (including mine). check all your plugs and wires #8 is always the toughest. then go to advanced or wherever and get it scanned for free. that should steer you in the right direction.
my thought is one of the wires isnt on all the way i would just take all them off then check the plugs to make sure there not black with oil, then make sure the plugs are tight, then put the wires back on and make sure you put some muscle behind it also sometimes you think there on and there really not. and make sure threre connected to the coil packs also.. hope this fixes it good luck man.
I had my car tuned when I got the exhaust installed, you should have it tuned maybe. And defintely check the ignition like everyone's saying. It might be a bad plug wire or something as little as that. Good luck to you!
