Pulleys worth it?
Old 09-17-2006, 02:56 PM
tonic's Avatar
Question Pulleys worth it?
I was looking at the SLP pulleys and ASP pulleys. Are these worth it? Are there any negative effects? Thank you,
Old 09-17-2006, 03:20 PM
dajodsterman's Avatar
with autos there can be alternator charging probs but replacing the alt pulley when doing the mod can fix that. Changing the alt pulley does lessen the performance gain of changing the pulleys in the first place though. Some people with A4's raise there idle speed instead. I think to probably around 700 rpm in gear but not for sure. If you haven't yet try using the search to get more info. In the mean time maybe someone else with more info will respond.
Old 09-17-2006, 10:19 PM
dragonrage's Avatar
Not worth it.
Old 09-17-2006, 11:49 PM
Blk97WS6's Avatar
i had them on my auto LT1, huge PITA because of the alternator. expecially at night with the lights on and either the heat/ac going
Old 09-18-2006, 12:35 PM
v8hunter's Avatar
I'm suprised at the responses so far...most people will say that the pulley is worth a tenth in the quarter mile. I have an auto (without the alternator pulley) and have not had any charging problems. Do your research and then make your choice whether to get one.
Old 09-18-2006, 12:49 PM
ibanez7's Avatar
pulleys dont do much for lt1 but they do increase hp on ls1.
I will post my dyno sheet this weekend of it the difference!!!
Old 09-18-2006, 01:01 PM
DarkhorSe_SS's Avatar
what are some pulley choices for an m6 ls1??
Old 09-18-2006, 04:14 PM
SuperSlow02's Avatar
the same, you just have to change the alt pully sometimes on an auto because when your sitting still in traffic with it in gear the engine is still under some load while a M6 is always in N while sitting still.
Old 09-18-2006, 04:17 PM
Chris Gage's Avatar
A pulley on a LS1 is worth it.... it is one of those mods that go well with other. The more power you pruduce, the more of a factor the puley will play. I had a 25% underdrive pulley on my previous 98 Z
Old 09-18-2006, 09:21 PM
Name some guys... thx
Old 09-23-2006, 10:00 AM
Chris Gage's Avatar
ASP, Powerbond, SLP, ATI I believe March has one now but not sure
Old 09-23-2006, 12:11 PM
Lucas'02SS's Avatar
I would say it is worth it. I think it a good 10 to 15 WHP. I wouldn't do it before like LTs or a cam though. That would be one of the later mods I would do.
Old 09-23-2006, 12:18 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
There's this little thing called a search engine....find one and type in "f-body underdrive pulleys" in the search box.
Old 09-23-2006, 01:29 PM
Andros's Avatar
i put my a4 in Nuetral when im coming to a stop or sitting in traffic. so do i need an alt pulley?
Old 09-23-2006, 01:32 PM
98hardtopZ's Avatar
why would you do that?
Old 09-23-2006, 01:43 PM
00T\A's Avatar
Crank Pulley on an LS1 is worth about 5-10 rwhp.
Old 09-23-2006, 01:45 PM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
I think I've heard about people do'n this before. I think the myth is that its supposed to save a bit of fuel. Alot of people pop em into N on a down hill and let her roll on down. Which might work,....I guess,.......but in traffic or come'n to a dead stop sounds to me like sheer !
I'm personally look'n at SLPs pulleys to get after I'm done with gears and a TC.
Old 09-23-2006, 05:05 PM
Moderator
davered00ss's Avatar
I would get the SLP or Powerbond pully. I have the SLP, but have not installed it yet. I'm lazy.
Moderator
I should have done it when I did my cam.
Old 09-23-2006, 05:13 PM
austin21's Avatar
do i need an underdrive or an overdrive pully for a non-dd M6..or does it matter if its a non-dd
