Stall noise?
It only whines at 2000+ 1st through 3rd when gotten on it a little bit... Once it unloads into 4th there is no more whine... No whine at idle or regular acceleration under 2000.
Originally Posted by 94z28L
k well that eliminates that possibility, kinda a dumb question but is it completely full of fluid? converter all the way on the input?
Originally Posted by BlackHawk T/A
And it didn't do this before? These cars do have a slight whine but if you have a loud exhaust you can't hear it.
Originally Posted by performabuilt
Hi since it stops in fourth I doubt its the pump , but since you added a cooler that is where i would look make sure there is fluild flowing through it ,the whine could be planets starving
LV2XLR8- I believe that this bearing noise that is making noise when loaded. It could be a bearing in the tc or in the trans however you said that it happened after the tc swap so I think that is where to look first. Vince
Originally Posted by Vince @ FLT
I can't see how it could be planets when in third gear everything is turning 1:1.
Originally Posted by fastSS2002
I have had the same problem since my fuddle was installed.I was told it was gear whine,but i took that with a grain of salt.
ttt
ttt
