Stock stall loosened up to 2500 ???? question need help ASAP!!!
Restricted User
ok so im having alil frustration lately with my turbo setup...basically the car is a pig out of the hole...no boost=no power..im making real nice power from about 2800 and up.. anything under that rpm i feel the car kinda "slow"
**my question is that i have a guy that can re-adjust(loosen) my converter to give me a 2500 stall speed for about $200... He's "been in business for 20 years.." bla bla bla tha guy seems to know his stuff and has alotttt of info on these trannies... which looks promising...SO GUYS PLZ TELL ME if you think its worth it and if yout think it will solve this problem without being horrible on the street(cruising)...i really want this jus in case i have to roll somebody at a lower speed where my stock(1400 stall) SUCKS ASSSSSSSSS THANK YOU
IMO I wouldnt even **** with the stock converter. Adding more stall to a stock diameter converter is going to = more heat. You'd be better off doing as many recommend and spending good money on a good converter, such as vig, yank, etc.
Originally Posted by Yank
The stock converter will go to 2200 max and after that major parts replacement will be need, your best bet is to get a lighter converter and drop the weight of the stock 52 lb converter
Restricted User
The weight on out SS type converter is 28 lbs, loss in weight is also on a 10'' dia. not on 13''
so the power transfer to the wheels is faster, and as more HP is put to the ground at a quicker rate the launch is better, that is something that the stock weight converter can not match in any stall speed
Restricted User
You will see very little improvement from a restalled OEM unit. I had one done here at work, just for ***** and giggles ... it is exactly like stock, no difference. The weight of the beast kills any potential gains from modifying the OEM unit. If you want cheap and a noticeable improvement, get a 11" unit from a Trailblazer. Trust us, you will regret throwing away $200 for virtually nothing.
you can get a new converter for like 400... why screw with the old one?
