??What SIZE wheel ADAPTERS?????
1972 camaro.... want to put on the c6 z06 wheels staggerd 18 and 17s. the off set is +56mm for the 17x8.5 and +57mm for the 18x9.5???? Help Please!!
also if i get the same rims but with 10.5 in rear the offset is its +58mm and the front is at 9.5 with +54mm offset.
I have factory 17 and 18 inch magnesium vette rims on my 75 ta. I ended up using 2 1/2 inch adapters up front and 2 3/4 inch out back. That put the wheel/tire right out at the edge of the wheel opening as you look down from the top. I am not sure what the offset is on factory vette setups. Maybe someone else can chime in.
Is it possible to see a pic?? I wrote the offset of the wheesls up top if thats what you meant?Where did you get your wheel adapters??
I was also looking at...
http://cgi.ebay.com/ebaymotors/17-11...29387220QQrdZ1
does ANYONE HAVE ANY IDEA WHAT SIZE WHEELS I CAN GO IN THE BACK IF I GET 17X11 ZR1'S FOR THE REAR AND 17X9.5 FOR THE FRONT??WILL THEY EVEN FIT? WHATS THE MOST bs I CAN GO.. THEY ALL HAVE SUPER + bS ON THE WHEELS? WHAT WILL WORK??? This is gicing me such a headache!!
or the c6 zo6 wheels from tomzwheels.com
What I Did Is Put The Car On Jackstands Under The Rear Axle And Under The A Arms And Then Mocked Up My Tire Wheel Combo In The Wheel Well To Find Out Where Exactly I Wanted Them To Stick Out To. Then I Just Measured The Distance Inbetween The Rim And Rotor/drum. That Worked Perfect For Me. The Company That I Bought From No Longer Sells To The Public, But There Are Places On The Net You Can Get These. Just Shop Around. My Buddy Just Got Some For His S10 For Vette Rims And The Worked Great. But I Dont Remember Which Place He Got Them From. Both Him And I Have Driven Our Cars Very Hard With No Problems. Hope This Helps.
I Know 17x8.5 And 18x9.5 Combo Will Fit Easly, Wider Stuff Will Be Trickier To Determine Fitment. I Have Zero Rubbing With My Setup. Btw Tire Sizes Are 245/40/17 Up Front And 275/35/18 Rear. I Know There Is Room For A Little Wider Stuff Front And Rear, But That Would Take Some Careful Mockup.
