Meth users: Where did you mount the tank and pump?
You should have called to order your alkycontrol kit... Julio mods new replacement windsheild washer tanks as well as mods yours if you send it in. Complete with low alky warning sender and etc.
If it hasnt shipped out yet, call and ad it to your order!
Look in the pics section of their website and you will find a pic of one of our windsheild washer tanks with his touch added
Modded my own WW tank forget paying out the *** to have one done for you.
Plastic threaded barb, tap, and some nice epoxy and you are done. No leaks to this day. I did hack some of the threads off of the barb so it wouldn't protrude into the tank
My pump is mounted on the inner radiator support behind the fog light.
J
J
meth tank
I have a trunk mount with a three gal tank, my pump is mounted in the outside center of the tank. It has a spot in the center for this. Im now running two 13 gph jets and it uses it fast.
J
J
BTW.. there is no epoxy that is methanol safe windshield washer fluid is not straight methanol.
Originally Posted by Country Boy
Will the WW tank still work with a FMIC?
I run methanol, not WW fluid. The epoxy is on the outside to seal things up on an already tight tap. Doesn't leak at all. Spent 8 bucks on items and didn't have to wait for something to be shipped back. GM already provides the low level sender, plus common sense...keep and eye on it, you'll have no problems.
I get my methanol from the local circle track place, VP 2.60 a gallon.
Wasn't anything personal julio, I'm a DIY'er by nature and do things myself. If you want to sponsor or sell services on the board then feel free to contact PSJ or Nineball. Carl I've got a 31x12x4 FMIC in the nose, no interference at all with the GM tank FWIW.
J
Originally Posted by Alkycontrol Julio
I charge 35 labor to mod the tank..
J
My engine compartment is VERY limited on space, so I had Julio make me a new windshield washer tank & then mounted the pump on the nose behind the front facia. I just fits on the metal support structure (bumper) behind the license plate area. You have to cut out about a 6" section of the energy absorber crap. I think I posted a thread on here about it.....
J
J
The factory tank doesnt come with a low level? Is there an F-body model that comes with a sensor?
Thanks for the IC tip.. that will save someone some trouble.
Well when my WW tank went empty a few times before the meth kit, the light on the dash came on....so I guess I have something in the tank telling the dash light to come on.
Not a problem Julio, you've helped me out plenty in PMs on the buick board as well as here.
Wish I would have went with one of your kits, but had this one already, live and learn
To confirm.. look at your tank and you wont see any electrical connections going to it. Meaning you need to be careful to not get into trouble if you run low/out.. pretty/very dangerous if your tuneup requires it to work.
