Pics of the kinda new TA
Got the car a few months ago and never posted pics of it so I decided to throw a few up here, anyways the other car is my brothers and the truck is mine.
And for the mods:
Engine:
-Thunder Racing T-Rex cam (243/249 @ .050, .608"/.613" lift, 110 LSA)
-Patriot Gold dual spring kit
-Thunder Racing heat treated chrome-moly pushrods
-Rollmaster heat treated adjustable double roller timing set
-Stealth airlid w/ K&N filter
-Thunder Racing billet MAF ends, black
-Jantzer ported and black powdercoated throttle body
-LS6 intake manifold
-March underdrive pulley
-ARP Pro Series rod bolts
-Ported LS6 oil pump
-Prothane poly motor mounts
Exhaust:
-Edelbrock Victor Series drag headers: 1 3/4" to 1 7/8" stepped long tubes with merge collectors and off-road y-pipe
-Hooker cat-back
Tranny:
-Textralia clutch kit
-McLeod SFI 6.1 bellhousing
-Pro 5.0 shifter with Lou's Short Stick
-MBA billet shift ****, black with Trans Am logo
-Energy Suspension poly mount
Rearend:
-Driveline Solutions Ford 9" - 4.56's, Detroit TrueTrac, 31 spline axles, Strange SS case, Daytona pinion support, 1350 yoke, solid pinion spacer. 1/2" x 3" screw-in wheels studs
-Denny's Nitrous driveshaft (good to 2000 HP)
Suspension:
-Spohn Adjustable Tq Arm w/ front driveshaft loop and spherical rod end
-Spohn LCA's
-Spohn LCA brackets
-"BMR-style" Subframe connectors
Exterior:
-Fiberglass WS6 hood ($1300 parts and labor)
-17x9 and 17x11 Torq Thrust II's
Free Mods:
-!CAGS
-!EGR
-!A.I.R.
-! A/C (have all parts to put back on)
-Throttle body coolant bypass
-NGK Iridium plugs
-Taylor Thundervolt 10.4mm wires
And for the mods:
Engine:
Exhaust:
-Hooker cat-back
Tranny:
Rearend:
Suspension:
-Spohn LCA's
-Spohn LCA brackets
Exterior:
Free Mods:
-!CAGS
-!EGR
-!A.I.R.
-NGK Iridium plugs
well...Im not gonna brake it but im going to be puttin in a Futral F14 or TSP Torquer2 which will give me about 400/385 so its kinda overkill in a way, but then again, bet safe than sorry. OH yeah, and the 4.56's ar a dream for someone who love TQ like myself !!!
MrJ Im not sure about the tire size. the rears are to bald to really even drive when its wet, so ill be ordering a pair of toyo T1's in the near future and I am away at college so a cant go out and check for you sorry.
BlueZ yes its a TT, has around 430HP on high boost and 370 on low specs are:
PERFORMANCE:
JWT single pop Charger
JWT ECU/Ashpec Eprom
Nismo 555 injectors
Rebuilt engine
Wiseco 87.5 pistons
3 angle valve job, new valves seals
rotating assembly balanced
JWT sport 500 Turbos
Extrude honed exhaust manifolds
GD split downpipes
Test Pipes
B&B resonated Tri-FLow Cat-Back
JWT Street Clutch
UR lightened pulley
Profec b boost controller
Stillen Short Throw Shifter
HKS Intercoolers
Z1 One piece drive shaft
NA rear end
ELECTRONICS:
Techtom MDM-100
SPI Boost Guage
Greddy 60mm EGT Guage
Greddy 52mm fuel pressure guage
Apexi S-AFC II
SUSPENSION / BRAKING:
ES subframe/differential bushings
ES steering Rack bushings
Eibach Springs
KYB AGX shocks/struts
300 degree camber kit
Stillen Anti-Sway bars
Stillen slotted sport rotors
Axxix MM pads
SS brakelines
Speedbleeders
EXTERIOR:
Stillen GTZ Front Spoiler
Japan Spec Clear Corners
Racing Hart Tracer Wheels
17x8.0 Front, 245/45 sumitomo
17x8.5 Rear, 275/40 sumitomo
PERFORMANCE:
Nismo 555 injectors
Rebuilt engine
Wiseco 87.5 pistons
GD split downpipes
Test Pipes
JWT Street Clutch
UR lightened pulley
HKS Intercoolers
NA rear end
ELECTRONICS:
Techtom MDM-100
SPI Boost Guage
Apexi S-AFC II
Eibach Springs
Axxix MM pads
SS brakelines
Speedbleeders
EXTERIOR:
