Rossler 4l60E
Well i know rossler makes some serious trannies, no i dont have one yet but I have seriously been looking at getting one seeing as how (from what I know ) lingenfelter uses them in alot of their cars. strong as a rock from what i understand, but I have noticed by reading a recent post RPM's are the major killer on these things so if your running hy power numbers at lower rpm you may be ok with a beafy build but either way do your research i'm at the same spot as you so far but rossler is a GOOD name.
I have on and have had great luck with them. here is a post about my transmission when i had the brake installed.
https://ls1tech.com/forums/automatic-transmission/482258-4l60e-transbrake-installed.html
https://ls1tech.com/forums/showthread.php?t=482258
