What gaskets are needed?
Old 09-22-2006, 11:59 AM
lilbuddy1587's Avatar
Default What gaskets are needed?
Hi everyone,
I'm getting ready to put my motor back together and I'm curious as to what gaskets I need?
The only gaskets I can think of are the oil pan gasket, head gaskets(have those already), water pump gasket, and exhaust mani/header gaskets(already have). What else am I missing here? Any help would be much appreciated!
Old 09-22-2006, 01:36 PM
Beasst8's Avatar
Timing Cover Gasket.
Old 09-22-2006, 04:50 PM
thanks beasst8, BUMP!
Old 09-22-2006, 08:42 PM
TTT, please, someone has to know! ?
Old 09-22-2006, 09:47 PM
jay_99z's Avatar
I would definitely replace rear main seal and rear cover gasket. It's a huge pain if they leak after it's back in the car.
Old 09-22-2006, 10:11 PM
Ferocity02's Avatar
Oil pan gasket
Front cover gasket
Rear Cover gasket
Front main seal
Rear main seal
Oil pump o-ring
Head gaskets
Coolant crossover seals, if you are not using LS6 coolant tubes
Water pump gaskets
Valve stem seals
Valley cover gasket(reusable)
Header gaskets(reusable)
Valve cover gaskets(reusable)
Old 09-23-2006, 03:24 AM
Originally Posted by Ferocity02
Oil pan gasket
Front cover gasket
Rear Cover gasket
Front main seal
Rear main seal
Oil pump o-ring
Head gaskets
Water pump gaskets
Valve stem seals
I have a FAST 90/90, so would my coolant tubes have been changed over when it was installed?
Old 09-23-2006, 10:39 PM
Ferocity02's Avatar
I'd suggest it, yes.
Old 09-23-2006, 11:01 PM
ArcticZ28's Avatar
You should have a tube crossing over in the front and one crossing over in the back (or blocked off on each head in the back). If you have a set of interconnecting tubes that look like a stick figure then those are the stock coolant tubes. Those would need to be switched over to the typical block off's in the back and one crossover in the front.
