4x4 Firebird
Dont remeber the show, but it comes on SPIKE TV on weekends with a guy named Stacy, its bout offroading and trucks, maybe its called trucks? either way he built a car called the SlingRay. it was a stingray corvette that was basically same thing as that firebird...only a corvette. It was badass, pushing 500hp or so. Looked like a lot of fun
Slingray is from mr jesse james on monster garage
Make: Chevrolet
Model: Corvette Sting Ray
Year: 1973
VEHICLE SPECS
Engine: 454 Chevy big block
Pistons: Chevy stock (eight)
Camshaft: Edelbrock Performer from Jeg's
Heads: Chevy stock
Induction: Edelbrock Performer carburetor/intake manifold from Jeg's
Ignition: HEI
Exhaust: Hooker flanges, zoomie headers by Jesse (chromed)
Cooling: stock
Transmission: 400 turbo
Converter: 2,200 rpm stall
Drive Shaft: custom fabricated with chain drive and jack shaft to front axle (four-wheel drive)
Rear Axle: Ford 9-inch
Front Axle: 1984 Toyota 4Runner front end purchased from junkyard
Steering: original Corvette steering box turned 90 degrees to link up with Toyota front end
Front Suspension: racing air shocks from King Shocks, custom-fabricated linkage
Rear Suspension: racing air shocks from King Shocks, custom-fabricated four-link with panhard bar
Front Brakes: stock Toyota
Rear Brakes: none
Front Tires: Mickey Thompson Baja Claw 33x13.50-15LT
Rear Tires: Mickey Thompson Baja Claw 35x15.50-15LT
Wheels: Mickey Thompson Challenger 15x10
Interior: The bulk of the original interior was removed.
* A custom-fabricated roll cage was installed.
* Stock seats were replaced with Cobra racing seats from Subé Sports.
* A nitrous tank from Nitrous Express was mounted in the storage space.
Electronics: Nitrous was wired to the horn; a nitrous purge was mounted on a Maltese-cross template under the dash.
Body: The original Corvette fiberglass body was only slightly modified; the hood was removed.
Paint: House of Kolor white-sealer base coat, then a blend of 12 different colors created with true-blue pearl, magic-blue pearl and snow-white pearl.
Height: 52 inches
Width: 69 inches
Length: 185 inches
Ground Clearance: 8 inches
Weight: 3,000 pounds
Make: Chevrolet
Year: 1973
VEHICLE SPECS
Heads: Chevy stock
Ignition: HEI
Cooling: stock
Rear Brakes: none
Height: 52 inches
Width: 69 inches
Length: 185 inches
