Mrbowtie26
09-22-2006, 04:38 PM
I am puting together a SLP 402 shortblock with afr 225 heads, fast 90/90 setup. Car is a 2000 TransAm. Question is do I use the stock coolant crossover that connects to the front and back of both heads as the Valley cover that came with the shortblock was in the way a little and I had to tweak the lines to get them to fit. I've seen a crossover that just goes in the front of the heads from one to the other and each hole in the back plugged. Is this what I have to do and if so where do I get the crossover pipe ? from the dealer ? Also I assume the plugs would come with the pipe ?
Thanks
Ron H. :bang:
Thanks
Ron H. :bang:
