tailhousing keeps breaking
last wk my tail housing broke while on the dyno.so I ordered a built tranny one from a reputable comp. and on the dyno with the new trans.the same thing happened.The new tranny is fine but for some reason during deceleration something is causing the tailhousing to break.What can this be?alignment issue maybe?
everything(suspension)stock .torquearm, pinion angle, lca etc.My new shop is putting it up on the lift to check everthing out right now while we wait for the new tailshaft.Just wanted to know if anyone has experienced this or who has heard of this.Any help in the search process is much appreciated.
thanks
john
thanks
john
I had a Spohn trans mounted TA and an aluminum DS...Not sure what went first, but it ended with a split tailshaft and a DS that looked like it was cut in half by a steak knife on the dyno...I switched to a cross brace mounted Spohn TA and a good 3" steel DS and have had zero issues...Get the TA off of the trans...
--Alan
--Alan
good post for people to know about the driveshaft. i guess i'm lucky i havent broken any yet with heads and cam, stock TA, and just broke my built trans hardened output shaft
got a call tonight from my tuner who whent to the shop who is doing the trans.Still waiting for the new tailshaft and had the driveshaft sent out and got new tranny mount and ordered a TA relocation kit.anything else I need to prevent this from happening again?
well like I mentioned I got the poly transmout,bmr relocation bracket and had the driveshaft balanced and checked out.I was just wondering why Im just learning about this about the tailshaft.I did not even considered taking the TA off the tailshaft before.I thought you had to make a ton of power before I had to worry about it,and after posting this thread I realized it did not take much to damage the tailshaft,maybe someone put this in the stickies so that more people will look into this more and just get the relocation bracket and poly trans mount before adding more horse power.I know most people want to spend their money on go fast parts,but I guess its better than leaning the hard way and having the tailshaft go out on the track or wors on the street.So I hope this it put in the stickies to help more people out,cuz its not an issue that is brought up alot,but when I posted it I could tell that it was more common than I thought.Thanks for everyones feedback and stories reguarding this issue and like I said I hope that this is made a sticky so others will learn
thanks
john
thanks
john
