focking slave cylinder
Old 09-23-2006, 01:35 AM
rudyzturbota's Avatar
Angry focking slave cylinder
ive replace my slave cylinder 3times now,, but they only last a week or longer, what is the deal with that, ive done the drill mod, master seems oka, but are you supposta till if its bad? ive about had it taking it out an puting a new one in, why does it keep focking up. what usually happens is i will be a high rpms then i go to shift an the pedle stays to the floor, a get it home an try bleeding it again(i have a mightvac) but the fluid comes out of the bellhousing, i see no leaks around the quick disconnect fitting, or around the master, so please tell me why this could be? could it be that my clutch is puting to much pressure on the slave, the clutch is a spec4, some body please help me
Old 09-23-2006, 11:39 AM
1998z28ss's Avatar
I doubt its the pressure. I put a cheap advance slave behind my ram powergrip HD pressure plate which supposedly has the highest clamping force. I havent had any problems yet. Untill you said something about the leak I was going to say to bleed it real good.
Old 09-23-2006, 12:56 PM
go i bleed it realy good an everytime my pendle would be great an run for about a week, then when im racing it well go back down, an leak some or all the fluid out. then i will let it set for a day an fill it back up an try to bleed it, an it just comes out or the bell housing. is there a more of a high performance slave cylinder out there or one that is better built?
Old 09-24-2006, 12:08 PM
CW00BlackTA's Avatar
It sounds like you have another problem that is causing your issues. If your slave is leaking, you are damaging the seals somehow. How well are your lines insulated from heat? Are you sure the slave is not over-extending? Too much vacuum while bleeding? Just throwing out some ideas to consider.
Old 09-24-2006, 04:36 PM
so i take it no one else out there has never had this kind of issue with there clutch system before. an the braded line is rap in rubber hose as well. an if i was to much vacuum wouldnt the slave go out then not in a few days. thanks guys i do appreciate your help keep it coming.
Old 09-27-2006, 09:21 PM
need some help guys, has this never happen to anyone
Old 09-27-2006, 11:30 PM
one2run's Avatar
it's happeing to me. i replaced the master first, thinking it was that. waste of money because i am still have this issue. bleed the stuff out of it (went through a bottle of fluid) and still no luck. i had even tried to vac bleed. i am going to replace the slave next and i doubt taking the torque management out in the tune did this to the car.
Old 09-28-2006, 03:47 AM
will ive replace my slave three times now, the funny thing is the guy at autozone tells me to get one with the life time warinty, i ask him is he going to pull the tranny back out to replace it,lol, i dont think so. did u check out my link i had on McLeod
Old 09-28-2006, 03:53 AM
http://mcleodind.com/product_guide.html
check them out, tell me what you think, since youve got the same type of deal, better off buying something better then having the same part missing up.
Old 09-28-2006, 04:34 PM
come on, some body please help me, i think im going crazy over this,grrrrrrrrrr
Old 09-28-2006, 04:52 PM
BIG_MIKE2005's Avatar
Your just in a **** boat all by yourself man. LOL
I have never heard of people havin this problem either. Something weird is goin on with your car.
Old 09-28-2006, 05:04 PM
no no, i called McLeod an we figured it out, im going to post a new thread, that could be use as a sticky.
Old 09-28-2006, 05:19 PM
ss1129's Avatar
please do. Im so sick of the hydraulic clutch bullshit. I really really really want to make a cable one.
Old 09-28-2006, 05:44 PM
its up tell me what you guys think about the thread, did i explain it well or no.
Old 09-28-2006, 05:58 PM
ss1129's Avatar
What did you figure out?
Old 09-28-2006, 06:05 PM
check out my new thread about slave over exstending
Old 09-28-2006, 09:51 PM
z28drag's Avatar
did u put a shim plate behind the slave if not thats it.......
Quick Reply: focking slave cylinder
