Automatic Transmission - Gears & Stall
View Full Version : Gears & Stall
ss4chad
09-23-2006, 02:38 AM
Ok, am I understanding this correctly? If you have shorter gears (3:73) is it wise to go higher on the stall? When you guys say "A Loose Converter" are you refering to someone who has taller (2:73 or 3:23) gears that it takes them more gas pedal to get the car moving? If this is correct then should I consider for my application (3:73 gears) a stall in the neighborhood of 3600? If so then will I still have a streetable car? In other words, a car that I can drive around town, to the golf course and to Church without turning 4000 rpms just to get moving? Or should I stick with a 3200? Thanks for the help!
RevGTO
09-23-2006, 09:00 PM
It's not that you SHOULD get a higher stall converter, but with your lower gears it'll feel tighter than it would on a 2.73 car. With your gears, LT's, and mild cam, a 3600 should be about perfect.
MNR-0
09-23-2006, 11:53 PM
3.73+3600 stallie should need no more than 2000-2200RPM to get moving. Moderate throttle will flash it to 3000RPM.
ss4chad
09-25-2006, 11:29 AM
Cool, thanks guys!!
ss4chad
09-25-2006, 01:41 PM
One more thing, what should the STR be for that 3600 Stall? I'm oredering a Vigilante and they want to know what STR I want! Thanks for the help guys!
import slayer
09-25-2006, 04:23 PM
2.5 str
ss4chad
09-27-2006, 02:55 AM
Thats a lock up right? Not a multi disc? What's the difference?
12secSS
09-27-2006, 08:41 AM
For street driving you'll want a 2.1-2.2 STR, but if you drag race on drag radials or better tires occassionally, then opt for the 2.5 or higher (depend on how sticky your tires will be and how strong the drivetrain is). Vigilante has lock up converters, which can be single disc (OEM configuration) or multi (triple) disc units. In your case I would opt for a 3600 with 2.2 STR. :)
jmm98LS1
09-27-2006, 09:29 AM
.....In your case I would opt for a 3600 with 2.2 STR. :)
x2....I have a 3600 2.2str converter and love it. The car still rolls forward idling in gear and isn't loose at all (to me anyhow). Even with the 2.2 str, street tires will go up in smoke with any significant throttle in first gear, so save up for some drag radials. :D
ss4chad
09-27-2006, 09:31 AM
Would the 3200 Vig have the same STR of 2.2? I want to make sure that I still have a streetable car as I spend most of the time on the golf course rather than on the track. I have seen lots of guys on here using the 3200 and they say it actually stalls to 3600. Your thoughts? Hey, arent you the B&M guy? Hows that shifter coming? I cant wait to see what it looks like in my car!! Thanks for the help in my stall selection, this is a great website!!
12secSS
09-27-2006, 11:20 AM
Yes, I am the B&M guy. :) The final bugs are being worked out, you guys will love it. No problem on the stall selection assistance.
BlackHawk T/A
09-27-2006, 08:37 PM
I would recommend it the other way around. Higher STR for street driving to help you get around without having to rev to the moon, and lower STR for a track car that you want to launch hard with no traction worries and pull a little harder up top. Basically tighter for the street, looser for the track.
