View Poll Results: Which heads make a better curve?
Dart 205
27
34.62%
PRC LS6
30
38.46%
Patriot LS6 Style
14
17.95%
Other (specify)
7
8.97%
Voters: 78. You may not vote on this poll
Dart 205 vs PRC LS6 vs Patriot LS6 Style
LS1Tech Premium Sponsor
You might also throw in the all new PRC Street 5.3l Cylinder Heads. They feature big 2.02/2.04 intakes, 1.57 or 1.60 exhaust valves & PRC Double Spring kit for only $1199!! This combo uses a pretty small 220cc runner & flows very compareable to the LS6 head we offer with a much smaller runner! Flow vs. flow out of the box it flows atleast 10cfm over the dart at every lift point!
220cc runner
63cc chamber
big valves
Double Spring Kit
Decked to your specs
$1199 COMPLETE!!
Keep your eyes open for flow info & flow videos! I had a independent bench flow one fo these 5.3l heads at over 315cfm @ .600" right after a well known cnc ported 205cc head couldn't break the 300cfm mark!!
220cc runner
63cc chamber
big valves
Double Spring Kit
$1199 COMPLETE!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
That's great, Jason. Now the important thing: what about PTV clearance? If it's not at least as good as a stock LS6 243 casting, they're not worth much in today's world of big cams. But I'm interested, for sure.
On another note, I'm amazed that that many people have comparison info between the PRCs and the Darts, but failed to comment after voting. If they have enough info to vote, how can they not post about it?
The point is that after the typical valve job work and spring work, the PRCs aren't much cheaper than the Darts. Not enough to matter. So what is there to convince me that a few extra CFM on the PRCs is worth the sacrifice of using their bigger runner? The Dart has the smaller runner and the aftermarket strength and the aftermarket shaping on the combustion chamber. I'm not set on them. But I want to know why I should choose one over another. I think the curve would be prettier from the Darts.
220cc runner
63cc chamber
big valves
Double Spring Kit
$1199 COMPLETE!!
220cc runner
63cc chamber
big valves
Double Spring Kit
$1199 COMPLETE!!
I'll be giving you a call sometime next week about these heads.
220cc runner
63cc chamber
big valves
Double Spring Kit
$1199 COMPLETE!!
220cc runner
63cc chamber
big valves
Double Spring Kit
$1199 COMPLETE!!
Originally Posted by Black FormulaLs1
i would call vengeance racing and talk to ron..he's got some trick flow heads and some kick butt numbers up there..and flow charts to back it..when i do heads..thats exactly what i am getting..
Originally Posted by N4cer
Biased? You're selling them. Why you getting rid of them?
But of the budget heads out there I think the PRC's are the best bang for the buck right now. Especially when you factor in valve clearance and consistancy.
I had a set of PRC Dart Stage 2 heads that I sent back to Dart due to oil control issues. In return, the replaced my heads with some that they did a clean-up job on. They sent me full flow sheets from both sets of heads.
PRC ported Stage 2 Darts
Intake...........Corr CFM.......%Exh/Int
.200............146.7
.300............210.6
.400............267.3
.500............302.1
.600............310.3
.700............308.1
Exhaust
.200............103.3............70.4
.300............143.7............68.2
.400............182.2............68.2
.500............207.1............68.5
.600............223.0............71.9
.700............232.3............75.4
Darts with cleanup work performed at Dart (not sure if 205 or 225 ports)
.200............149.3
.300............205.1
.400............261.5
.500............293.2
.600............319.5
.700............334.0
Exhaust
.200............111.7............74.8
.300............153.3............74.7
.400............190.3............72.8
.500............218.0............74.3
.600............228.8............72.5
.700............235.7............70.6
All flow work was performed on a 4 inch bore with radiused inlets and no exhaust port adapter. I don't have flow numbers on what the box stock Darts flow, but I am sure someone on here has flowed a set. If not, call John over at Dart and I am sure he can get you some hard data.
Oh yea, while I have no hard data, I can tell you that the intake ports of the PRC ported Darts had much more material removed from the port than those cleaned up at Dart did. On the PRCs, the rocker bolt hang down into the port a good ways, while those cleaned up by Dart the rocker bolt just lays against the side wall barely exposed.
Hope this helps a little!
Galen
P.S. my vote...Dart
Exhaust
Exhaust
Galen
P.S. my vote...Dart
220cc runner
63cc chamber
big valves
Double Spring Kit
$1199 COMPLETE!!
220cc runner
63cc chamber
big valves
Double Spring Kit
$1199 COMPLETE!!
anyone have dyno # with these heads and this cam and all the bolt ons?
