38mm wastegate?
You can make as much power as you want with a 38. Now, keeping the power down is another issue. Wastegate sizing is a bit of a black art. I can tell you that my 40 mm worked just fine at keeping my T-76/360,383,388 down to 12 psi. . . that is until I improved my cat-back. I switched from an Aerochamber to a Magnaflow and now I can't get the boost below 16 psi. Later on, we built a T76/377 with a JGS 44 mm and no exhaust at all and it would go all the way down to 6 psi. It depends on the turbo, cid, desired boost level, and exhaust backpressure.
More exhaust backpressure -> smaller wastegate
More boost -> smaller wastegate
Larger cid -> smaller wastegate
Larger turbo -> ???
Larger turbo -> ???
Senior Member
now thats what I want to hear! I was told a Racegate would work with a P*S kit and it doesnt. It has a bigger flange than the standard. Anyone need a barely used Racegate?
Senior Member
See the problem is, the kit is amde with 1.5" tubing for the wategate which equals 38mm. So, anything over 38mm is a waste and Im not redoing the whole wastegate piping. I also have to have the 2 bolt flanges.
Well bro... im under the same situation and i just went with a JGS 38mm from Jose... stock 350 LT1/T76 and im aiming for a wee 6 psi at first. I hope all goes well!
^ I agree, try the new JS waste gate in a 40mm. Big turbo and low boost, you need something that will keep that valve closed, you may need a bigger W/G. I'd say, try it at first and see if you can get down to 6 or 7 psi comfortably.
Originally Posted by TransAm6383
where do I find a JS40?(what is it?) and you say its the same size as a tial 38mm??? Im looking to go down to 10psi on my T76....no lower...and i was told the tial would be too small.
