6spds, Cams, Bucking---What's the real deal
Old 09-23-2006, 05:27 PM
Pewterme's Avatar
Default 6spds, Cams, Bucking---What's the real deal
Had a cam installed a few months ago and drives great except when I get below 1500 rpm's or so. This generally isn't a problem unless I'm in first gear. You always hear the phrase, "It's all in the tune". Just how much can a tune do??? Is it possible to get them tuned where there is no bucking at all??? I'm not talking about a SD tune either. I've just got a middle of the road cam but wondering if it and bigger cams the tuning can completely eliminate the bucking. What's been your experience? I did try to do a search on this subject but had little luck. Thanks
Old 09-23-2006, 06:56 PM
bigdsz's Avatar
The 110 LSA isn't helping anything, however I am surprised when you say you are having problems in first, particularly with 4.10's. I'm assuming your cam is a Comp XER.Surely you knew this cam was going to have a nasty idle compared to a 114 LSA. Maybe the tuner can give you a little insight.
Old 09-23-2006, 08:10 PM
2001bluerata's Avatar
Alot of bigger cams are going to give you that bucking at lower RPMs. Mine does it in 6th gear at 60-65 when I let off the gas. I also have 4.10s. It does that b/c of the lope, the cam wants to make power and you're just not in the sweet spot.
Old 09-23-2006, 08:13 PM
austin21's Avatar
That explains alot .hmm learn something new everyday on tech ..thanks
Old 09-23-2006, 08:34 PM
Beasst8's Avatar
Yeah, I have noticed my MS4 does it quite often!! I am having 4.10s put in and a tune in the next few weeks.
Old 09-23-2006, 08:43 PM
Insanekamel's Avatar
im tuned but still have stock gears (3.42) it it bucks like a **** under 1600 rpms... but its ALOT better after the tune but still there.
Old 09-23-2006, 08:47 PM
Pewterme's Avatar
What the 110 LSA is helping is to give me ideal valve events which give me good power under the curve. I also did want a little bit of a nasty idle. The tuner did say this was part of having a little more aggressive cam, but just looking for more opinions.
Old 09-23-2006, 08:48 PM
After my cam swap, I just had to take it out for a test drive b4 installing the moser w/4.10s, which was installed the next day. Hell yeah it bucked bad w/ the stock gears, gotta go bigger.
Old 09-23-2006, 09:28 PM
N4cer's Avatar
Yep, you're on a tight LSA which is gonna happen. Add to that the whole 1500rpm thing, and there you have it. Get the RPMs up, or get a less aggressive cam. A tune can't get rid of that.
Old 09-23-2006, 09:42 PM
eallanboggs's Avatar
It's called lugging the engine. There is always a perfect gear for your vehicle speed and engine RPM in every situation. Maybe you need a CVT transmission instead of one with fixed cogs.
Old 09-23-2006, 09:54 PM
Black FormulaLs1's Avatar
my formy does it too with a 112 lsa...stock heads and all..i even got the 373's no help there lmao..i just live with it..
Old 09-23-2006, 10:28 PM
Ksett's Avatar
Why not a speed demsity tune? The tuner can put your MAF back on after the tune and you will still have the drivabilty benefits from the tune. This is what I have on my car and it's made a huge difference from the dyno tune I had previously.
Old 09-23-2006, 10:31 PM
RoastEmSS's Avatar
a tune can really help bucking, i know a local guy with a T2 cam in his ls1 gto, it used to buck bad under 2K rpm, he retuned it and has it dialed in to where it has little to no bucking under 1500 rpm
Old 09-23-2006, 10:46 PM
You're gonna have it just get the rpms up or put the clutch in.
Old 09-23-2006, 11:13 PM
LS1 Tech Administrator
Patrick G's Avatar
The guys who are telling you to live with the bucking or that your LSA is too narrow have not enjoyed the benefits of a proper driveability tune. It takes hours and sometims days to perfect, but when it's right, you'll have little to no bucking below 1500. I go through 4 school zones every morning and I have to crawl 1100 rpm in 3rd gear. I can't have bucking so this was a real priority for me. Bottom line, the guys who are telling you it can't be done need to stand out of the way from the guys who are doing it.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 09-23-2006, 11:21 PM
N4cer's Avatar
"Little to no" bucking: yeah I have very little. But saying that he'll have none... that's doubtful. But I'm game to be shown!
Old 09-23-2006, 11:33 PM
99blancoSS's Avatar
Its in the tune but the cam as well. The guy who tuned my car got it perfect. Smooth as glass great numbers tr224 112 lsa. He tuned an almost identical car but with an FM13 and it had some surge he could not get rid of.
Old 09-24-2006, 12:57 AM
LS1IMPULSE's Avatar
look at mods in sig, and all i have is a quick cruising home tune from HP tuners...I know exactly waht your talkin about, i would get a real tune but ill be putting new cam in shortly.
Old 09-24-2006, 02:12 AM
muncie21's Avatar
Rode with a guy today that had a MN6 with a 224/224 on a 112 and no bucking at all. I'm going to go with door number 3: The Tune!!
Old 09-24-2006, 07:05 AM
00T\A's Avatar
A good lsx tuner and some real world tunning will reduce your bucking problems.
I have a very small cam but i can idle through a parking lot at 850 no bucking
Quick Reply: 6spds, Cams, Bucking---What's the real deal
