what offset to get??? zr1's
My buddy has a 97 z, he is getting black zr1's and need to know what offset to get. He is goin to put the eibach sportline lowering kit. Should he get the 56mm offset or the 38mm? Thanx for n e help.
What size wheels is he getting? If He's going with 17x9.5 all around, I'd recommend the 56mm offset... Its perfect for that size wheel. If He's going with the 11" wheel out back I'd suggest what Urban Legend said.
but with 17x9.5's i would also go with 50mm over 56mm, the 56mm stick in a little too much imo. But if you only can choose from 38 or 56, I would pick 56 for sure.
Originally Posted by Xsta Z 28
38 mm offset 9.5" wheels fit perfect on F-Cars. My Fikses are 38 mm. . . . . Now, since you want to drop it 2" . . . . maybe the 56 mm would suit you better.
