head gasket replacements?
Old 09-23-2006, 08:08 PM
eLTwerker's Avatar
Default head gasket replacements?
I'll be upgrading to Patriot ported 243s and the f13 cam soon. Will I need new head gaskets? If so, will GM replacements do? I've of leak issues with some Cometics plus they're far more expensive. Thanks!
Old 09-23-2006, 08:32 PM
Beasst8's Avatar
Yes new ones and yes the GM ones should be fine.
Old 09-23-2006, 08:50 PM
sprydncamd ta's Avatar
i used the fel pro mls coated head gaskets and so far no leaks or problems
Old 09-23-2006, 10:12 PM
eLTwerker's Avatar
it doesn't say so on the site, but do Patriot assembled heads come with gaskets?
Old 09-23-2006, 11:01 PM
GuitsBoy's Avatar
I cant be certain but I think they stopped shipping with new gaskets a while back. My friend has had good luck with mr. gasket .042 composite gaskets at ~20 each. You can get GM 5.7L gaskets for ~25 for the set, or 6.0L gaskets for ~35. The 6.0L gaskets are .054" thick, and the GM 5.7L gaskets are advertised as .060, but usually measure at or around .054 as well. If you have the P to V clearance, the .042 gaskets will get you a tighter quench and a bit more compression.
Old 09-23-2006, 11:13 PM
csmc711's Avatar
How about some part No? I have searched this site about head gaskets and cant find much on the GM MLS and Felpros that would be the best for our engines
Old 09-24-2006, 02:21 AM
muncie21's Avatar
If that's $35 for the set of 6.0L gaskets, can you point me in the right direction where you go them? I haven't been able to find that good of a price.
Old 09-24-2006, 06:06 PM
ISeeRed's Avatar
The part number is 12498544 for a set of two 2002-2004 LS1 Corvette/Camaro/Firebird Gaskets.
Ray
