Drag Racing Tech
need advice what size wheels and tires
Old 09-23-2006, 08:24 PM
Brianss1's Avatar
Default need advice what size wheels and tires
What size of drag radials and wheels should I get if I do not want to do any inner fender or lip work.Looking for the largest size you can run.15 inch weld wheels is what I am looking at skinnys up front also.Let me know your size and pics would be great.I have a 01 WS6,cam and heads,3.73 12 bolt,complete BMR susp,3400 midwest stall,around 432 rwhp and 387 tq.
Old 09-23-2006, 11:44 PM
gator's 99TA's Avatar
i dont see you needing anything more than a 275/50/15 m/t radial. any more tire and you will slow down.
Old 09-25-2006, 12:24 AM
CamTom12's Avatar
agreed
Old 09-25-2006, 07:21 AM
Brianss1's Avatar
OK,thanks for the replies.So anything bigger would require some work to make fit and not be any better for my set up ?
Old 09-25-2006, 11:36 AM
CamTom12's Avatar
no, you could fit a 28" tire in there very easily. Mine required no extra work over the 26" tire other than some adj. LCA's.
What we're saying is that with your gear and power level it might be too much tire for you. A larger tire can slow you down
