Fueling & Injection - converting truck fuel injector harness
gametech
09-25-2006, 12:57 AM
Who has the simplest solution for converting the fuel injector harness on an '02 silverado to accept the car style longer injectors. The plug going onto each injector is different, and I would like to avoid cutting and soldering on new ends. The reason for the swap is that I'm planning to put on a victor intake and edelbrock only sells the rails set up for the longer style injectors. Besides, I already have an extra set of mototron 60's. The victor intake will allow the necessary space to run pipe from the whipple to an intercooler and back to the intake without having to alter the accessory drive system as would be necessary with the ls6 intake I was going to use.
bluecajun5.3
09-25-2006, 08:11 AM
this is what you need.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD%2D2400&N=700+0&autoview=sku
i'm swapping to an ls6 intake along with a 97/98 vette fuel rail, since the fuel system is return style on pre '03 trucks.
gametech
09-25-2006, 07:22 PM
Exactly what I was looking for. Thanks.
BLWN1
12-07-2006, 09:09 PM
So are these adapters or new plugs, kinda confused...? Price is nice either way....
BC5.3.........What are you doing for accessories, vette or f body?
Ford_Assassin
04-21-2010, 06:58 PM
Another run at the top...
Nasty N8
04-22-2010, 10:57 AM
These are crimp on plugs they make pigtail connectors as well but no PnP adapters for the truck inj.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
