Turbo 6m cars
Old 09-25-2006, 11:04 AM
trod's Avatar
Default Turbo 6m cars
OK I have a question for the turboed manual cars. How are you guys getting off the line? The reason I'm asking is because since I've gotten the turbo my times suck a--.
Old 09-25-2006, 11:41 AM
00turboT/A's Avatar
Harlan 2 step off the line. I use to leave at around 7PSI on my old set up. Not sure with the new one yet we'll see
Old 09-25-2006, 12:28 PM
Turbo LS1 SS's Avatar
an sts off the line with an m6 is painful. i never had a 2step, but what i used to do was blurp the throttle continuously, and launch as it was low on vaccum
Old 09-25-2006, 12:34 PM
1BADCTS's Avatar
Could you help clarify this comment for the non-turbo saavy people?
Old 09-25-2006, 12:48 PM
trod's Avatar
where can I get the 2-step?
Old 09-25-2006, 12:54 PM
n2o
n2o's Avatar
How about a set of slicks and leave WFO?
Old 09-25-2006, 01:12 PM
trod's Avatar
Well I have Nitto drags and I tried 3500rpm,4000rpm,and 4300rpm. All that did was BOG DOWN. Last run I launched as if I was at a street light. That turned the for the night but it still was not where it should be!
Old 09-25-2006, 04:08 PM
n2o
n2o's Avatar
Leave at 6000. I wouldn't think it would bog there.
Old 09-25-2006, 04:17 PM
detroit_903's Avatar
Default Re:
I bought a MSD-2 step module for my turbo m6. You will also need to have a msd al/btm ignition to make it work with the 2-step. I have not been able to try it out yet cause I also had a new clutch installed. But it's making 5 psi -boost from a dead stop with a 4k pill. The car is defently going to leave very hard from a stop with this 2-step now
Old 09-25-2006, 05:11 PM
JAvenger007's Avatar
trod you made 480+ on just 5.5 with stock cubes? what turbo?
Old 09-25-2006, 07:37 PM
Coy
Coy's Avatar
5,000 rpm sidestep on E.T. streets...
Old 09-26-2006, 12:46 AM
00turboT/A's Avatar
Basically the 2 step studders the motor making under a load and in turn building boost up to whatever boost amount you have set and you let go of the button off the line and you leave at whatever boost your at so your boost is already there and there is no spool time.
Old 09-26-2006, 03:42 AM
ninetres's Avatar
Synergy (a sponsor) sells them and they don't reauire all kinds of expensive ignition componets
510-synergy
Old 09-26-2006, 07:57 AM
trod's Avatar
Its the t60-1. Why? Should it be more HP?
Old 09-26-2006, 03:50 PM
Baghdaddy's Avatar
In my turbo car, while on the 2-step it also retards the timing. Thus creating more late burning, expanding gas and spooling the turbo.
Quick Reply: Turbo 6m cars
