flames out exhaust
flames out exhaust
I was racing a 5.0 the other day and after we got pulled over for racing (stupid ) The cop said that he thought I might be running a little rich because he said he saw flames coming out of my exhaust. I have also noticed a loud pop noise once I push the clutch in right after a WOT run. I have had the car tuned and the dyno sheet says that my air to fuel is right on! I run longtube headers with an off road y-pipe with a single cutout that I keep open all the time. Any ideas or suggestions? Is this or could this be a problem in the future???
On my z, if i revved up high in 1st gear and let the rpms drop and stabbed the throttle a bit, i was told that flame came out of my cutout. I am guessing it had something to do with a changing a/f on the decel. It probably couldve been tuned out with some custom tuning, it never did it with the cutout closed btw. I didnt think of it as a problem.
Anyways, did that cop give you a ticket?
Originally Posted by pHEnomIC
. . . I am guessing it had something to do with a changing a/f on the decel. It probably couldve been tuned out with some custom tuning . . .
Also correct, tuning can correct the problem.
someone told me it has somthing to do with the hot air coming out of the exhaust hitting the cold air outside, makes it pop and a nice fireball somtimes. but he may have been talking about somthing else. when i had my duals dumped fire used to come out but the tail pipes got rid of that.
11Second Club
I doubt the pipes prevented the fireballs. They just contained them. I only get them when the cutouts are open.
When the car is running at WOT, your A/F ratio is as rich as it ever should be. If you drop the throttle all of a sudden, then it takes a split second for the PCM to adjust, so it gets extremely rich for just a second. Therefore, you get a burst of unburned fuel into the pipes, which will ignite in the pipes. If there's enough fuel or short enough pipes, you'll actually be able to see it.
Nothing to concern yourself about.
