Synthetic oil switch from regular at 50K
I've been on a free oil change program at the dealer -- every 3K using regular oil since new. Since the warranty expired at 50K this spring, the dealer has posed bogus repair quotes and other scams (like quoting $150 to replace the battery because they saw OLD corrosion evidence -- but didn't notice a new GEL battery in there when refilling the oil - WTH?).
>> we doubt the dealer has used the exact same oil every change.
I want to switch to synthetic at 50K and change it myself now. Anyone think it's a bad idea? wear patterns? horror stories? risk of leaks at seals? I know I should have done it when still under warranty.. .
I drive the LS1 2002 TA pretty hard. This might make it better.
you used non sythetic in an ls1? shame.. switch to sythetic , i beleive only the older motors with older style gaskets were the ones habing problems going to sythetic.
Not trying to steal the thread....I've got about 2500 on motor is sig....my builder says I can stick with cas gtx 10/30, or switch to synthetic...I was thinking of switching to cas synthetic blend.....any comments
my brother was burning up gears in his race car in two races using convent. oils. He switched to synth and hasn't burnt a set in 2 seasons now.
I appreciate the input. Goodbye Dealer !!!!
