Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Winter beater... 95 Cherokee
Old 09-26-2006, 01:53 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Default Winter beater... 95 Cherokee
I have a neighbor who has a 95 Cherokee 4.0 for sale. It's the square body style, 4dr, 4x4, with cloth seats. Has about 95,000 miles on it. I might be able to get it very very cheap. Anyone have specific things I should look at on it? I mean beyond the transmission and stuff like that. Do these things have electrical problems? They said sometimes the wipers have just stopped.
Old 09-26-2006, 03:07 PM
Luna's Avatar
I don't know of any specific problems with them but I worked on my neighbors 01 4.0L cherokee to replace the radiator fan motor and it is a MAJOR PITA to work on. It ended up also having a few bad relays. But accordiing to my father the 4.0L motor will run forever and ever and ever and ever.
Old 09-26-2006, 03:23 PM
Tenured Member
Outlaw Motorsports's Avatar
Is it all time 4wd or par time?
Old 09-26-2006, 03:28 PM
texinteg's Avatar
I own a few cherokee's. They run forever if you take car of them. You can beat on them all you want just do simple maintence. Check the rear main seal for the engine cause they are known to leak. The water pumps are known for going out along with the timing chains having alot of slack. Make sure all the vacuum lines are in good condition cause they effect the way these vehicles run in a big way. Also check the exhaust manifold for cracks as they are known to crack. They are very easy to work on. I have done a 4.5 in lift with simple hand tools. Good luck and have fun. Once you lift it you will always wanna go higher. Not saying your gonna lift it but most people do because its cheap. Check out naxja.com for any other info you need on the cherokee.
Old 09-26-2006, 03:44 PM
LS1Tech Co-Founder
I believe it's selectable 4wd.
Yeah the only thing that concerned me was the part about the wipers just stopping. I don't have a long commute so if that happened when I first started driving it it would not be a big deal.
Old 09-26-2006, 10:11 PM
Tenured Member
Rainx
www.jeepsunlimited.com
These were the cheapest to lift because you could do the front to rear spring swap and gain 4 inches for about 250 bucks.
Old 09-26-2006, 10:17 PM
LS1Tech Co-Founder
Interesting. I have seen a 3" lift on Magnus' stuff, looks decent. I'm guessing 31's fit no problem.
Old 09-27-2006, 05:59 PM
I8RICE's Avatar
Check both diff's, trans, transfer case, and engine for leaks. When I worked at an oil change place, almost every cherokee would have something leaking regardless of mileage.
Old 09-28-2006, 11:15 AM
LS1Tech Co-Founder
I like how a 3" lift looks, any pics of 4" lifts?
Old 10-16-2006, 09:28 PM
LS1Tech Co-Founder
I bought it, the exterior has some scratches and dings but it has a lot of newer parts.
Old 10-17-2006, 05:50 PM
PipesTA's Avatar
The 4.0 is an unstopable John. I had a 96 Grand that had just over 150k. No problems at all. I now have an 01 with the 4.0 and it's been good to me so far. Good luck
Quick Reply: Winter beater... 95 Cherokee
