can i JB weld my air tube on my header back on?
Originally Posted by GR33N GoblinM6
no you cant... that header will get well over JB weld's temp rating of 300*C. you need it properly welded.
Originally Posted by ICRAZY6
long tubes and don't worry about the air tube.
looking at jb welds website... seems like if it would work on all this, it would work on this though... says its rated to 500*F, how hot does a stainless header get?
AUTOS, MOTORCYCLES, MECHANICAL
fuel tanks
radiators
cracked engine blocks
transmission & rear-end casings
cylinder heads & sleeves
generators, starters, water & fuel pumps
axles & hubs
valve guides
press fit bearings
crankshaft pulleys
casting defects
door stops
key ways
stripped threads
body shop repairs
Originally Posted by Camaroholic
I tried to seal a plug in the exhaust manifold on my truck. JB Weld smoked right out. It will NOT work, I promise.
My EGT ranges anywhere from 650-800 degrees at idle, up to over 1300 degrees. I use the AIR tube hole as the EGT bung.
I had to JB weld my AIR block off plate on my stock manifolds after it blew out. I haven't driven it much since then but it doesn't look like it is going to last long. Race LTs here I come...
