Clutch is Rock hard
Old 09-26-2006, 07:59 PM
JRick212's Avatar
Default Clutch is Rock hard
Just installed Ram clutch with new slave and master. I used the shim with the clutch. I did the drill mod and made sure that the line was free of debris after.
I've got the thing all back together and I'm trying to bleed it using the mityvac while someone pumps the clutch in and out slowly method and the clutch is rock hard can't move it.
Any ideas?
Old 09-26-2006, 09:33 PM
MrEddie's Avatar
If the quick-disconnect (master to slave) isn't fully engaged, then the pedal can be real difficult/impossible to depress.
