Rod is knocking....what would you do?
WEll, I bought a ton of **** for my build but now it seems like a rod is knocking in my motor, what shortblock would you get, and I don't need any ideas about 454's or anything, I have somewhat of budget seeing how I just spent 7K-8K on the first round of mods. I have been thinking of 402 or 408 but I bought the TSP 200cc terminator heads and they aren't designed for that bore. I also have a MS3 cam, it should be big enough for most block in my range I think. here is a list of mods I have already.... What would you build?
Tsp 200cc Terminator heads
Tsp MS3 Cam
Tsp Gold Dual Springs
Tsp Moly Pushrods
Tsp Tuning
LS7 lifters
Melling HP/HV Oil Pump
Fast 90mm Intake
TPIS 90mm TB
SVO 42# Injectors "Green tops"
NX Wet Kit 100hp shot w/ purge & heater
85mm Z06 Maf
Powerbond underdrive Pulley
PCV Catch Can
Haltech Stinger CAI
Kooks SS Long Tubes
Kooks SS X-pipe w/ QTP electric cutouts
B&B Tri-Flow SS Exhaust
Lingenfelter 255lph Fuel Pump w/hotwire harness
Lingenfelter Hardened output shaft Cryoed & micro polished
Hurst Short Throw shifter
Motive Cryoed 3.90 gears
Textrallia ceramic Clutch
17# Lightweight Billet Flywheel
Tsp MS3 Cam
Tsp Moly Pushrods
Tsp Tuning
LS7 lifters
Fast 90mm Intake
TPIS 90mm TB
85mm Z06 Maf
PCV Catch Can
Haltech Stinger CAI
Kooks SS Long Tubes
I saw this.
347 Kits
Includes: New LS6 GM crankshaft, Clevite-77 Main and Rod Bearings, Diamond Forged Pistons, Diamond File-Fit Piston Rings, and 6.100” Scat I-Beam Connecting Rods.
***Kit #1 – 347 Flat Top - Pistons will set .011” out of the hole
Diamond Flat Top with 2-Valve Reliefs (-4cc), 3.905” bore
Approximate CR’s with 65cc Head: 0.055” Gasket – 10.43 to 1; 0.030” Gasket – 11.09 to 1
Kit Part Number – LS6ROT347 – Sale Price $1029.95
Here.. https://ls1tech.com/forums/sponsor-sales-specials/580173-fall-inventory-reduction-sale-sdpc.html
347 Kits
Originally Posted by waterbug1999
I saw this.
347 Kits
bore
Here.. https://ls1tech.com/forums/showthread.php?t=580173
347 Kits
bore
