heater hoses
heater hoses
I'm in the process of running heater hoses. I read that a "H" pipe should be put in before the heater vavle so that there is always coolant moving around the t-stat when heater vavle is closed. What is everybody else doing, "H" pipe or no "H" pipe? Issues with or without "H" pipe? Thanks
Hi mjls1, how i your camaro coming?
I did not use a H pipe either and never had any problem with my setup. I think I remember seeing the thread where someone was having the problem you described and he cured it with a H pipe. He had the problem because of the HVAC unit he was using.
Hi schitzo, I think he had installed a classic auto air unit. I'm using the same a/c set up. Just not sure if I needed "H" pipe or not. I recently got the car running . Started right up. I could not of done it without this board! Now to decide what color to paint it...
You only need a tee if you have a heater control valve. The valve will shut off the coolant flow through the heater core when the air is on. These are very common pieces in older chevy's even up into the 90's. On the LS1 the t-stat will not get coolant flow over it without heater core flow so a small tee can be used in the heater hoses to allow the coolant to circulate over the stat. I would just not use a heater control valve unless you are running hot with the air on, then the valve ann help a little.
Andy
Andy
This subject was brought up once before, and I questioned whether the heater valve was a bypass type (keeps coolant flowing back to the water pump when in the closed position). Someone anwered by saying "look at the heater valve." Well, I don't have a late model (98-02) heater valve to see if it is a bypass type. Anyone?
I know the stock thermostat has 4 holes in the diverter to presumably keep some coolant flowing in order for the thermostat to see when the water gets hot. The diverter also is on a spring to presumably bypass incidental high pressure water under higher RPM's when the thermostat is still closed.
Andy1
Andy1
Andy
Andy
Originally Posted by mjls1
It has the heater control valve and shuts the coolant off to the heater core. I talked to the manufacturer a while back and they said they had no known issues with this problem. But I have read that some are having touble with running hot as soon as shutting the valve. The heater hoses are 5/8". My next question is if I use a "H" pipe, what diameter pipe should be used for the center (cross over) pipe? Smaller like 1/2" or same size 5/8"? Thanks
Andy
