Please help! GM can't find the part I need!
Old 09-27-2006, 12:03 AM
WHIPSrx7's Avatar
Default Please help! GM can't find the part I need!
Hi All, Please read all!
I need to buy an oil pick up tube bolt for the f-body oil pan pick up tube. I've included pictures as well. The f-body pick up tube's bolt is on the opposite side of the bolt for the corvette's pick up tube bolt. The dealership cannot find this part because it appears that they have the number only for the Corvette bolt. If someone could please give me the dimensions of this bolt, it would be most appreciated and the sooner the better! Really need to find this tomorrow (Wednesday). Thanks a lot in advance!!!
Craig
Old 09-28-2006, 07:43 PM
99camarosupersport's Avatar
um, if they only have the part # for the LS1 vette bolt buy it, i'm about 99% sure it would work. Same engine, assuming it has the same size bolt, regardless if it's on the opposite side or not... Hope that helps, if not....just use a ruler and measure your threading.
