Broken Tranny Mount...
Hey all, I was having my true duals put in tonight when my mechanic noticed that the tranny mount was torn in half. I was wondering why when I would nail it I would hear a thump under the car (torque arm hitting body?) So I told them to order me a poly tranny mount. Only question is I have poly motor mounts and hear that some times you can crack the bell housing for the tranny if you use a poly tranny mount with poly motor mounts. Is this true or is there anything I can use instead of a poly tranny mount? Thanks and help would be great.
-Philip
-Philip
Originally Posted by nukeemall454
man forgot to say dont about your question though
dont know answer to ur question sorry for the mix up dude. but yeah definetly fix it man its not good. callem up and ask the company whats up.
Originally Posted by BlackHawk T/A
There is nothing wrong with using both poly motor and transmission mounts.
Originally Posted by 2000slpss
you confused poly mounts with solid mounts. you arent supposed to use a solid motormount with a solid trans mout cuz theres no where to flex. both poly mounts is fine
I would go with a stock rubber mount. Put a urethane one in my lt1 formula when the stocker ripped and it made the car feell like a POS. Lots of noise and vibration throughout the whole car. Went back and got a stock rubber one. If its a high HP race car go urethane If not stick to the rubber. BTW im not some pssy who hates noise -- I run longtubes ORY with an open borla as a DD 100miles a day.
