Black Smoke issues
Old 09-27-2006, 06:25 PM
PSUstanghunter's Avatar
Default Black Smoke issues
I own a '99 SS with the STS rear mount kit making a comfortable 10psi. I've noticed lately that the car will make full boost, but then around 3300 rpm it will buck. Also every now and then when i hammer it, it throws out black smoke, alot of it. Ive never had any problems with the car since I purchased it. I was wondering if you guys had any thoughts before I haul it into my mechanic and spend a ton of cash i dont have right now. Thanks in advance.
Old 09-27-2006, 06:37 PM
Smearin's Avatar
Holy Richness Batman!!!
Whats your a/f ?
what size turbo?
Sounds like your running rich.... real rich....How much smoke?
I was gonna say choking the turbo... but at 3300.. hmmm
maybe your tires are just spinning and then your hooking?
Old 09-27-2006, 08:35 PM
The car has been running fine though, it was tuned. It's not spinning the tires. If I mat it it bucks like 3 or 4 times then goes normal. Someone help me out here
Old 09-27-2006, 10:04 PM
Smearin's Avatar
Do you have a wideband? whats your a/f? What size turbo? any unusual sounds coming from the turbo?
Anything to work off here?
Old 09-28-2006, 04:28 AM
I have a wide band, the a/f doesn't look any different than it normally does. The turbo is a t-76.. nothing sounds unusual something specific I should be listening for? Please help guys
Old 09-28-2006, 05:55 AM
You could probably also consider the "buck to be a hesitation? It does it 2 or 3 times around 3300 or so and then things kick in and go.
Old 09-28-2006, 07:13 AM
turbolx's Avatar
$10 says spark knock nearing peak torque/cylinder pressure...
Old 09-28-2006, 07:55 AM
Frost's Avatar
What does the wideband SAY? Are you on a stock bottom end? What is actual timing at the point of bucking? Do you have a set of colder plugs in the car?
Old 09-28-2006, 11:38 AM
Aside from the fact that it may be running somewhat rich, is there a possibility that stale gas could cause the bucking/hesitation?
Old 09-28-2006, 04:36 PM
Smearin's Avatar
Whats your a/f @ WOT? Are you running premium? What plugs are you running?
Old 09-28-2006, 04:39 PM
JD_Z28's Avatar
You could be burning oil. Have you checked your resistor and cats.
Old 09-28-2006, 09:03 PM
Ok guys, I put some fresh gas in the car today and drove it around.. It is now appearing to be running fine. I think I may still be a little rich, which I will go get a dyno/dynotune done to fix that. I let the car rest a couple of different times for like 2 hrs the first time and like 6 the 2nd and it is running just fine and dandy. Odd.
and correction i have a narrowband a/f guage.
Quick Reply: Black Smoke issues
