4l60e pistons
Pin diameter will be different from the 1-2 to the 3-4 accumulator piston on most all 4L60Es, unless somebody swapped a 700R4 style big pin 1-2 accumulator housing onto the 4L60E (which I have seen), so they shouldn't be the same if everything is factory. I would recommend getting the correct piston(s) from Vince.
Sean
Sean
