95 chevy TBI
95 chevy TBI
I was thinking about putting an LS1 in my 95 TBI truck. It has a 4L60E transmission in it. What would be my best route? I have a torque convertor I took out of my 98Z28. Will the 95 4L60E in a truck bolt bolt up to a 98 LS1 and can I reuse the convertor?
9 Second Club/LS1TECH Sponsor
Due to the bellhousing depth change you can't use the 98 TC with the 95 trans. You can use the 95 trans with the LS1 engine using the available GM spacer kit (spacer/bolts/flexplate). You'll need to re-use the 95 TC though.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
I was also thinking of doing the same for my 94 Suburban. I am in the process of purchasing a 2002 6.0L with trans and transfer case. What mods would be required to install this into the big Sub? Would I have to get an aftermarket harness from somebody like Howell or someone like that?
Hmmmmmm.....
__________________
www.speartech.com
www.speartech.com
