can i put my oil return bung here
http://www.pixloads.com/files/view/3713/jm0006.jpg
basically in the front of the pan looking towards the radiator for a gravity feed return or will i still need a pump
You can put it in the front just below the lip. Vortech has been putting it there for years. Go to there website and find the installation instuctions for the ls1 blower and it will have the oil tap intructions there also. On your setup though im not sure if the turbos are high enough for a gravity feed line though.
Here is my thread with my oil pan tapping info:
https://ls1tech.com/forums/showthrea...&highlight=tti
I would not install the return in the middle of the pan for clearance reasons. Also, dont forget your oil pickup tube is just behind the pan on the passenger side. Don't damage it!
