For those of you hooked on GC..
I know it's hard to find that stuff, so here are two alternatives:
Either of these will suit you just fine. I'm so sick of hearing people whine about not being able to find GC.
Originally Posted by Patman
American made Syntec is indeed a group 3 hydrocracked petroleum base, but the German made Syntec 0w30 we're referring to here is absolutely positively a 100% synthetic oil. In fact the synthetic base oil it uses is way more exotic than anything by Mobil 1. A bunch of us on BOBISTHEOILGUY.com contributed a bunch of money in order to get the German Castrol completely analyzed in order to determine the nature of it's base oil and we were very happy to find out it uses an extremely exotic base oil which is fully synthetic, extremely shear stable and uses no polymer viscosity index improvers.
Originally Posted by DanZ28
On the other hand, read some of the oil analysis tests on different oils and see the difference.
I guess the oil analysis may mean something if you are planing on running 1 million miles. For the rest of us staying under 300,000 a good synthetic is more than good enough.
Dan
Originally Posted by Stanger88
1/2 the posts I see say you get MORE piston slap with GC over M1 and 1/2 the mosts I see say its the opposite.
It's best to just do your own research, when possible, such as in this case. Drain the oil you have now, send it off to get analyzed, and pop some GC in your engine. Run it for 3k miles, send it off to get analyzed and compare to the old analysis. It's a pretty good bet that it will have better results than the typical synthetics people run (excluding Amsoil which is top notch as well). If it doesn't for whatever reason, you've only lost 10 minutes of your life to read the analysis and whatever it cost to get the oil analyzed. Then you can know for sure. However, if you're like me where you really don't want to take time aside to do this sort of thing, you can trust the multiple people on here who have shown actual test results of the GC that proves it stays cleaner longer than most other oils, and the many people who have nothing but good things to say about it regardless of its analysis (better pressure, less startup noise, etc).
I don't think anyone's saying American Castrol is going to seize your engine. It's just that the German stuff is engineered better to last longer and run cleaner. I don't see why someone wouldn't use something that lasts longer and is more effective in the long run. If it's that hard to find, obviously M1 isn't a crap *** oil or else so many cars wouldn't use it from the factory. However, there are oils better than it. German Castrol is one. If you can find it, use it. If not, no biggie. The only thing I have a problem with is people saying it's not all it's cracked up to be when it's been proven over and over again that it is. Sure it may not make your engine last a million miles but it may make it last 100k instead of 95k. To me, that's worth it when I drive a car that puts more hp to the ground than 4 hondas. To some people it's not. Opinions like that can be argued, the fact that it's a superior oil cannot.
IIRC, that second oil i posted meets the specs for the VW TDI diesel engine which has some of the HIGHEST standards around. if it's good enough for those motors, then it sure as hell is good enough for your LSx.
