T5 5th and Reverse are inop
A coworker here has an 89 V6 firebird. His reverse and 5th gear aren't working. When you try to put it in reverse, it won't go all the way into gear, and just freewheels. If you're driving and put it into 5th, it will go all the way into gear, but freewheels also.
Ideas, thirdgenners?
Originally Posted by 8a8mfh
See edit above. It's the rear of the input shaft that might be broken off.
