Need Help Asap
Old 09-29-2006, 04:02 PM
99TA04's Avatar
Default Need Help Asap
I ran out of gas so i called my friend to bring me some gas and some we put about 3 gallons and the car still won't start and info would help.
Old 09-29-2006, 04:19 PM
EchoMirage's Avatar
Might have clogged the fuel filter and/or injectors. If there was any **** in the bottom of your tank, it would have sucked it into the filter. Try that first. If it still won't run, then maybe the injectors are totally clogged. Get a new fuel filter first, if it runs, use a very good fuel injector cleaner, like Chevron or seafoam, or take it to a shop that can use their professional cleaners.
Old 09-29-2006, 04:33 PM
2001NBMZ28's Avatar
Running low/out of gas is a no no. Can you hear the fuel pump prime when you turn the key on?
Old 09-29-2006, 04:53 PM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
Rule of thumb,.....try not to let you tank drop below a 1/4 tank so often. If you do it alot, it can over work you fuel pump and kill it.
Old 09-30-2006, 04:18 AM
staringback05's Avatar
turn the key to the on position and let it sit for a second, then try to turn it on
Old 10-02-2006, 03:45 AM
99TA04's Avatar
tried that i am thinking i burnt the fuel pump so time for a new one
Old 10-02-2006, 01:30 PM
easiest way to change it is just cut the alumn where the hump is above the fuel tank instead of dropping the whole thing.....you access the pump since it will be right there on top of the tank....the metals about 1mm thick
