PCM Diagnostics & Tuning - Please show me your timing table (OLSD) for a large cam w/ bolt-ons
Red99TA
09-30-2006, 05:02 PM
I'm running OLSD w/ an LC-1 WBO2 to get the AFR where I want it (tuning the VE table). I just need help w tables below 2000 rpm. This thing bucks like a damn bull :bang: at TPS of 6% or less from about 1100 rpm up to 1800 rpm. Idle dips to like 400 often coming to a stop but that's a seperate issue. I logged it today to try and see what's going on w/ the bucking. The timing is jumping but only by 1 degree each time it bucks. The AFR jumps around +/-.5 each time as well. My high and low octane tables match, primary and secondary VE tables matched, DFCO disabled, OLFA set at 1.00 across the board. My PE table fattens it up to 12.5 up to about 4500 then 13.3 above that. Base spark in park and drive are matched as well. Throttle cracker disabled below 50 mph, and I haven't messed w/ the throttle follower. Does someone have a tune w/ no or minimal buck w/ similar mods. TIA :)
ninobrn99
10-01-2006, 05:11 AM
sounds like it could be raf it its happening when getting off or under 10% throttle. I dont have a copy of my tune on me and wont until next weekend, but heres a screen shot i have of my timing table.
http://i11.photobucket.com/albums/a175/ninobrn99/timingcopy.jpg
hope that helps. dont forget to make the changes to your idle spark as well as the low/high octane tables.
