Optima battery a direct drop-in?
Old 10-01-2006, 01:06 PM
beaSSt's Avatar
Default Optima battery a direct drop-in?
The Optima site says that the Red Top requires a "puck" adapter to allow the bottom mount bolt to secure the batter.
Do these puck adapters come with the battery or are they needed?
Old 10-01-2006, 01:19 PM
2001NBMZ28's Avatar
The 75/35 is a direct replacement, got one in my car.
Old 10-01-2006, 01:32 PM
Ironxcross's Avatar
what's the advantage of an optima battery over a regular battery?
Old 10-01-2006, 02:06 PM
SeriousPWRTRIP's Avatar
optima is a gel-type sealed battery, so it wont leak. It also provides better holding of charge and produces good starting power. I have an optima in my car and wont go back to a regular style battery. Of course, I have aftermarket speakers and 2 subs in the car also, so that helped my decision when I decided to go Optima.
Old 10-01-2006, 02:19 PM
shaun's Avatar
so will switching to a red top help hold more voltage?
when i run my manual fan switch on high it drops the voltage down quite a bit then if i give a little gas in n it comes back up and when i drive off
