heads for g5x2
But either way, you still should mill enough that you need to flycut. AFR's give no additional clearance. I was also scared crapless of the flycutting. Then I realized how many people do it. And LGmotorsports and Brian Tooley both said it's as easy as changing oil, and "if you refuse to flycut you're saying no to 25hp". Why are you afraid to flycut? That's the bigger issue.
You can run a G5X2 without flycutting. You just won't have the high compression that you could have. It's great with stock heads. Keep it. On a 112 LSA. I'm just saying you're refusing to make more power just 'cause you're being vaginal and refusing to flycut. I just ordered the tool and will be flycutting mine in a few weeks if you want me to let everyone know how it is to pop my flycutting cherry.
Hi,
Did not flycut. Check sig (have AFR205cc milled to 59cc) and G5X2 on 114. Cometics = .040 as well. Revs to 6100rpm (understanding is stock LS1 revs to 58/5900rpm). I have much more drivetrain loss than many others due to drivetrain loss, so don't base your results on my numbers.
However, to compare. I went with a mailorder tuned LS1 Hotcam (219/228&.525/.525@112LSA). Truck did 347.6rwhp with the same setup and a quick tune by LG yielded no better than 355rwhp. Of course, I'll admit...N4cer's comment about saying "no to 25hp" could have convinced me to do it.
Seriously consider the AFR205s. Its kind of hard to say "no" to 40 guaranteed rwhp.
I wouldn't say that. I like AFR's, but my tuner told me not to waste the money... that the ones he's seen come in haven't been worth the extra money for 5-10 extra hp at the most. I actually also know another guy who is disappointed in his. That 40rwhp gain is NOT a sure thing.
I have a G5X2 at 112 LSA with AFR Heads milled to 60CC. I did not have to flycut. I am running a cosmetic gasket at .045. In my opinion, I would not flycut the pistons. Guys with a G5X3 at 112 LSA that did flycut and are running 59CC heads dynoed out at 6 more hp than I did, all on the top end. But, that was to be expected, given the larger cam. Mods were all the same and on the same dyno (SAE) on the three Z's that I saw (Mine is an X2 with AFR Heads and the other two were X3 cams with AFR Heads). This is on a Z06. One thing though is my car did pull a little better than theirs under the curve.
It is all up to you in the end. I would get forged pistons rather than flycutting, but that is just me. The reason I have not done this is that I have a new C6Z on the way and need to save all I can for this one.
JG853
JG853
Originally Posted by N4cer
I wouldn't say that.......my tuner told me not to waste the money...I actually also know another guy who is disappointed in his. That 40rwhp gain is NOT a sure thing.
Like it was said already - check out lgmotorsports.com and just look at how many times it was repeatable that there were good increases (I'm using the word "good" in an effort to show some humility).
Th dyno sheets are there and don't try playing the dyno-queen thing.....
Not posting anymore cause there's no need to....
