effect of more lift ?
Old 10-01-2006, 08:04 PM
oange ss's Avatar
Default effect of more lift ?
what effect would more lift have between two similar cams ? ex. 228/230 .571/.573 compared to 228/230 .581/.588 both 112+2 ? or would the differences be negligible ?....thanx
Old 10-01-2006, 08:19 PM
02TransAm/Batmobile's Avatar
same car, same mods, same heads, i think the .581 one would dyno a tad higher, . . jus a tad
Old 10-01-2006, 08:22 PM
oange ss's Avatar
car has TSP 5.3 heads, longtubes bolt-ons etc....
Old 10-01-2006, 09:08 PM
hammertime's Avatar
Depends on your heads, for the most part. If the increase in lift took the valve to a point where the port stalls or backs up, then you could potentially lose power.
However, .010 - .015 more lift would probably never net a measurable difference. I think you need .030 - .050 more to see a real difference with all other things being equal.
Old 10-01-2006, 09:12 PM
oange ss's Avatar
these are my heads with 2.04/1.575 valves
Old 10-01-2006, 09:15 PM
oange ss's Avatar
goin bigger this winter, but the larger valve sizes cut into my PTV clearance so i'm tryin to keep duration and lift in check...thnax for the reply
Old 10-01-2006, 09:54 PM
hammertime's Avatar
The duration will make a bigger difference in PTV clearance than an extra .010 - .015 lift would. It pays to check clearance so that you know you're safe. If you already have the heads installed, you could still check with a dial indicator and some checking springs to be sure you'll clear.
It looks like the flow continues to improve up to (and perhaps even beyond) .600 lift. Consider notching the pistons if need be. The extra lift is more time spent in higher flowing portions of that graph, giving you the potential to make more power.
Old 10-01-2006, 09:57 PM
oange ss's Avatar
cool, thanx for the help
Old 10-02-2006, 09:49 AM
PREDATOR-Z's Avatar
LIFT has nothing to do with PTV as max lift occurs close to BDC and not TDC.
Durations and Valve Events (LSA/Advance) is what you should look at.
