too big of a cam???
too big of a cam???
Comp 230/234 591/598 114
i can get a very good deal on this cam. but i just want a few other peoples thoughts on it and the rest of the set up.
stock bottom end
absolute speed stage 2 heads
300- 213- 149
400- 271- 192
450- 280- 204
500- 292- 219
550- 297- 222
600- 303- 225
ls6 intake
slp maf
stock TB
mid lengh headers to fit my thirdgen
cold air kit to fit thirdgen
2600 stall (i will need a bigger one with the new cam.)
as it stands now i have stock heads and comp 224/224 cam that made 335/325 at the wheels
stock bottom end
300- 213- 149
400- 271- 192
450- 280- 204
500- 292- 219
550- 297- 222
600- 303- 225
ls6 intake
slp maf
stock TB
Yeah, your clearance will be low. I left my clearance WAY too tight, but set my rev limiter low (6600). Probably can't fit that cam, since my 224 left me with .050" PTV. But you can rent a flycutting tool for $150, or buy the parts for $140 and use your old head to do it.
You'll have a driveable car, for sure. Here's my dyno graph from yesterday:
Originally Posted by orangeapeel
You were way low on power with that 224/224 cam seems like. I too have a bigger cam that has a pretty tame idle. 244/248 on a 115 though. Still 15° of overlap.
i kind of thought it was low also but the engine has been transplaned into a thirdgen with a 700r4 with a total custom exhaust set up. So there are not alot of cars out there to compair with.
at the time of the dyno there were a few other issues the car had. a bad knock senser and O2. i also dont know how well the tune is done. (only had the car for about 2 weeks before the dyno)
what is a safe distance to have for piston to valve.
also is it possable to do flycutting with the heads off but the engine still in the car?
and one last thing. what is a safe depth to flycut a stock piston?
Clearance necessary= .080 intake, .100 exhaust. You can cut at least up to .100, but unless it's a real big cam .060-.080 will do. Notching with the engine in the car is the way everyone does it, unless the engine is out for another reason.
yea, i have a 224/224 .581/.581 112lsa with a lid, headers and true duals. with no other mods besides pushrods, spings/retainers and i made ~380.
i would think you would have alot more power with your 224 cam....did make that power with the heads and ls6 intake?
dyno numbers were with stock heads.(only spring upgrade.) cam and ls6 intake
hmm... on a M6, with that cam and those mods you should be at 375 minimum....with an a4 you should still be at like 360-365 i would think at the minimum
i dont think it makes a big dif but its a 700r4. it was also running in the lowest timing tables because of the bad sensor. right now i am more intrested in if the new cam and heads will work well together
and i only said 410, because you dyno'd low before, so i think it will be low again. and this way, you can plan for 410, and only be happy when the numbers are higher since i dont see it being any lower than that
ЯєŧąяĐ Єl¡m¡иąŧøя ™
