Advanced Engineering Tech - Oil pan/filter flow directioin?
blackey
10-01-2006, 10:10 PM
If you remove the oil filter mount two oil passeges are there. One forward and one back (on the pan).
I've got AN fittings on these, but I'm not sure of the orientation as far as flow goes.
This is the ASA pan with AN fittings. Anyone know which is In and which is Out?
SNW Vette
10-12-2006, 10:57 PM
Hi,
The oil flows from the pump back through the driver’s side block, and then turns down passing into the oil pan and into the outer diameter of the filter. The oil passes through the filter towards its center and flows up the pan to the forward hole of the temperature sender crossover.
So the forward hole is the ‘out’.
The oil crosses over in the sender passage and than returns up into the block.
Good luck,
Steve
gun5l1ng3r
10-13-2006, 06:48 PM
Some of us (f-body guys) don't have oil temperature sensors.
You are damned lucky for owning a vette.
Ferocity02
10-13-2006, 06:53 PM
Easy enough to install an oil temp sender, cost you about $50 and a couple hours.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
