replacing wheel lugs on GTO
I have screwed up a rear wheel stud on my 2005 GTO. How do you replace the stud? Is there any way to do it without taking off the hub assembly? Thanks
ok first get the sand out of your vagina.
second, pull the wheel, caliper and rotor off. LOOK and see if you hit it with a big ****** hammer, will it go through all the way? if yes, then that answers your question, if no, that answers your question. if your not sure, then i have no idea
