Cam Installation Parts?
Old 10-02-2006, 11:00 PM
LS1BlackBird99's Avatar
Default Cam Installation Parts?
I am getting ready to get my parts together for a cam install in my 99 LS1. I'm curious as to what all parts that I will need for the install. I'm on a very tight budget. I'm going to be using 918 springs. Hopefully I can use the stock retainers/locks. I'm going to be going with the TSP 228R cam and hardened rods. Can anyone be very specific as to what is needed so I can pick it all up and never have to run to the store again? Your help is greatly appreciated!!
Old 10-02-2006, 11:06 PM
import slayer's Avatar
a lot of the time most places offer a cam kit that comes with everything you need for install I got mine through thunder racing.
Old 10-02-2006, 11:24 PM
NviouSS's Avatar
new gaskets (water pump, timing cover)
oil pump
timing chain
crank bolt
Old 10-02-2006, 11:40 PM
Ok I just purchased the cam install kit from TR. So I will need a new timing chain and oil pump for sure? If so where are those the cheapest and do I just need stock replacements? Can I get away with using the stock retainers/locks/seats/etc?
Old 10-02-2006, 11:46 PM
LS1IMPULSE's Avatar
a few specific tools, are optional but very helpful, goto Ls1howto.com they have a very good right up on the swap, aswell as parts and tools needed.
Old 10-02-2006, 11:49 PM
NviouSS's Avatar
i would since you have a 99. LS2 chains are $30. not sure how much ls6 pumps are. wouldn't hurt to get a ported pump. they run around $130.
Old 10-02-2006, 11:51 PM
chocolatemilk's Avatar
im pretty sure the kit will come with new seals and retainers as for locks you can use your stock ones. you are going to want a good valve spring compressor to make the job easier on yourself. you can just get a ls2 timing chain if you are on a tight budget and although its not really needed but highly recommended to get a ported oil pump. are you doing the job yourself?
Old 10-03-2006, 12:16 AM
RooRnZ28's Avatar
just be ready for suprises
Old 10-03-2006, 12:21 AM
Haven't decided if I'm doing it myself or not but if I'm not I need to have all the supplies for the install together and had a shop quote me $500 for the install.
Old 10-03-2006, 12:22 AM
Where can I find the LS2 chain and it will be strong enough? I just dont see why I would need to spend $160 on a double roller chain in the first place...
Old 10-03-2006, 11:36 AM
00slowredz's Avatar
i just bought all the install parts for mine....
dual valvesprings
titanium retainers
seals
seats
pushrods
ls7 lifters
ls6 ported and shimmed oil pump
ls2 timing chain kit
gaskets
head bolts
and last but not least ASPRIN....
Old 10-03-2006, 04:53 PM
dual valvesprings
titanium retainers
seals
seats
pushrods
ls7 lifters
gaskets
head bolts
I am going to try and get away with using the stock retainers. Where did you get the ls2 timing chain kit? Can you not just use a $30 ls2 chain alone?
Old 10-04-2006, 09:00 AM
LS1IMPULSE's Avatar
I got the rollmaster timing set, and if you just buy the PRC gold springs you can get dual springs, TI retainers, and locks for like 250ish
Old 10-04-2006, 08:51 PM
00slowredz's Avatar
well i bought a kit from MTI that came with pretty much all the internal valvetrain upgrades....but i got the ls6 ported oil pump and timing chain kit from texas speed. a friend of mine got just the timing chain and said he woulda been better off just buying the kit since its not that much more. got the kit for 109 shipped
Old 10-04-2006, 09:06 PM
04gtoBMXracer's Avatar
Ls2 timing chain set ... $71.95. Sdpc2000.com .. Scoggin dickey parts center.1-800-456-0211
Old 10-04-2006, 10:29 PM
thats what i did.
Old 10-05-2006, 11:02 AM
Cerebrex's Avatar
yes.. just get the chain. The stock sprocket is fine.
Old 10-06-2006, 12:11 AM
Thanks for all the help guys. Decided to just buy the LS2 chain alone and keep the stock retainers. Now I'm just trying to find the best deal on a TSP228R cam and some rods.
