Drag Racing Tech
Tire Decision - Radial vs Bias Ply for 6 speed car
Old 10-02-2006, 11:06 PM
potentz's Avatar
Default Tire Decision - Radial vs Bias Ply for 6 speed car
Hello,
I would appreciate any help in deciding what would be the better tire for my car. It is a 6 speed car that I plan on running into the 9's. I am having work done to the car to run a 15''x12'' drag wheel in the rear. I am deciding between the following tires:
Bias Ply
1. Hoosier QTP 28''x14.5x15
2. M&H 28''x14.5x15
Radial
1. Hoosier DOT Drag Tire 325/50/15
2. MT ET Street 325/50/15
3. Goodyear Drag Tire 325/50/15
I know some of the advantages of the Bias Ply are that they weigh less and I heard they launch better than the radials. The disadvantages are that the grow (causing more fender modifications) and cause more resistance.
Also, I will run either a bias ply or radial up front to match the rear.
Can anyone help?
Old 10-03-2006, 01:38 AM
94z28L's Avatar
im runnin the MT et street but not the radial, i believe there are two different MT ET street tires, one is a bias ply and the other a radial but i may be wrong on this one, either way i love em
Old 10-03-2006, 08:17 AM
Super Moderator
Reckless's Avatar
The MT Radial is also called an "ET Street".....hi Jeff
maybe this photo will help...Mike Brown's car on the MT Drag radials
Old 10-03-2006, 09:21 AM
LS1Tech Co-Founder
Nine Ball's Avatar
Damn those things wrinkle like slicks! I've seen the sides twist, but never the tread patch like that photo shows.
Old 10-03-2006, 09:31 AM
94z28L's Avatar
i just nutted
Old 10-03-2006, 10:31 AM
SiL3NtXWS6's Avatar
with a 6 speed car.. i would go with a stiff sidewall slick
Old 10-03-2006, 11:39 AM
CARTEK Racing
WS6TransAm01's Avatar
Im running the regular M/T ET Drag 28x10.5 15 [3055] Seems to be alright. It is soft and floatie on the big end but it hooks up very well!
Old 10-03-2006, 03:42 PM
Super Moderator
Reckless's Avatar
Yeah Tony, one of the local racers in a fox body Mustang had to stop using the MT DR's because he was going on the bumper every round. Jason Lee runs low 8's.
Old 10-03-2006, 05:32 PM
TwnTrboCE's Avatar
Mine would do that too. But I know when to lift. Well, I do now. I oilpan a year is my limit.
DO NOT RUN THE GOODYEAR RADIAL TIRE!!!!!!!! The absolute biggest pieces of **** out there. We actually tested a "newer design" set for them and gave them our feedback. This was after contacting and complaining about how bad the set I just bought was. The new ones were just as bad. Never heard back from them.
From what I have read the 6spd cars don't do as well on radials as autos. I would run a set of MT Race Slicks. But if your going to buy radials. MT all the way.
Old 10-03-2006, 05:52 PM
01_ram-air's Avatar
I agree.
I would just go with a M/T ET Drag for the 6 speed. If you were an auto I would say M/T ET Street Radial.
Old 11-12-2006, 07:40 PM
GTA91's Avatar
I'm running the 325/50/15 MT's with my new setup... 402/T56/9". It went 11.23 at 124 its first pass with a smoking clutch. 60' was only a 1.61... it went a 1.58 later that night but my clutch and posi are both shot. I'm hoping to go low 1.5's or maybe a high 1.4 on this tire come spring... we'll see.
Old 11-12-2006, 08:00 PM
gator's 99TA's Avatar
slicks all the way on the stick car.
Old 11-19-2006, 06:23 AM
stevieturbo's Avatar
ET Street Radials for me, although I'm yet to fully use their potential...
Old 11-20-2006, 12:32 AM
qqwqeqwrqwqtq's Avatar
I'm very impressed with the ET street radials. Ran 1.54 60ft and 9.8 @146 on 275 40 17's @ 3,800+lbs.
(It's a second slower on Goodyear Eagle GSD3's)
Old 11-20-2006, 09:17 AM
Nate_Taufer's Avatar
275/60/15 ET street radial here. Have yet to get it back to the track but I'm hoping for 1.6X
Nate
Old 11-20-2006, 09:54 AM
JoeyAnderson's Avatar
For a stick car, I say bias ply all day long.
I'm a stick car coming off the 6000RPM two-step on spray and I've never been able to hook a M/T drag radial to save my life.
On 26x10x15 ET DRAGs, I'm gone.
Old 11-20-2006, 10:21 AM
STL2SLO's Avatar
I run the MT drag radials on my M6 car, and they have treated me very well. I let loose on the clutch at 6500 and cut some high 1.6s.. Car is cam only, full-weight, 9" with 4.56s, and it hooks enough to make the car bog.
Old 11-20-2006, 11:37 AM
NHRATA01's Avatar
Best I ever cut on a 255/16 MT radial was 1.71.
Worst I've done on a 26x15 ET Slick was 1.69, and best was a 1.56. Car was setup the exact same way for all the aforementioned passes.
So for a 6 speed car, I say definitely go with a bias-ply.
Old 11-20-2006, 03:02 PM
SSwanner's Avatar
i like the hoosier 27x11.5x15 qtp's i just got. they seem to be softer then the m/t streets though. they seem to hook pretty well. i cut a 1.67 leaving at 4k (bogging) on motor, i'm pretty sure the clutch was slipping at the time also.
Old 11-23-2006, 09:20 PM
AINT SKEERED's Avatar
I have gone 1.63 as a best ever on bias ply 26x11.5x16 et streets and then switched to a 255x60x16 et street radial on the same track and same night to run consistent 1.59 's for the rest of the night.
I now run 275x50x15's but only cut 1.678 the last time out as the track was bad that night.
Quick Reply: Tire Decision - Radial vs Bias Ply for 6 speed car
