Drag Racing Tech
tubeless drag tire ?
Old 10-02-2006, 11:14 PM
import slayer's Avatar
Default tubeless drag tire ?
I noticed that on my MT ET Drags (which I run tubeless) when I am not using them they loose air faster than any street tire I have seen. Is this normal ?
Old 10-02-2006, 11:28 PM
94z28L's Avatar
dunno, mine lost a good amount of air tho as well
Old 10-02-2006, 11:48 PM
8 second club
G&HRacing's Avatar
Normal, Slicks with no tubes loose air alot faster. At the track my tires vary alot more through out the day with no tubes also. Still not worth the extra weight of tubes IMO.
We usually lightly coat the inside of the side walls with palmolive or some kind of liquid soap. After its aired up and before it dries it helps plug up the microscopic holes and helps them hold air better.
Old 10-03-2006, 11:10 AM
6 & 8 Second Club
mrdragster1970's Avatar
What he said, very common. Don't sweat it, and don't use the glue crap either.
Make sure you fill up before towing home, very bad to tow a car at race pressure.
Old 10-03-2006, 11:26 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Some rims will allow for more pressure loss than others. It can also happen when the slicks get to their life's end or the sidewalls are broken down. I had a set of slicks loss all their air within 3 days when I had 130 runs on them b/c the sidewalls were shot. New set with 30 runs hold all the air for one week.
Derek
